Hi. I was cleaning my r5 3600 with b450 motherboard to change thermal paste. i did not remove the cpu out of thw mobo to avoid damaging it or bending the pins and what not so i wiped alchohol immediately on top of my cpu. And did not notice that alchohol went in the sockets. Place thermal paste and installed heatsink then i did the same on my gpu. Assembled my right back up and it wont turn on. Removed everything including cpu and i saw dark spots on my cpu and my cpu socket was wet. Did i break both cpu and motherboard??
When i removw cpu still wont boot fans wont turn.
https://linustechtips.com/topic/1198170-issue-after-cleaning-cpu-thermal-paste/
"And did not notice that cpu went in the sockets"
do you mean alcohol went into the socket?
you don't need alcohol to clean paste off a CPU most of the time. a paper towel on its own should work fine. Or just put a little on the paper towel and wipe it, Don;t pour it on the cpu from the bottle.
If you let it all dry and there is no thermal paste in the socket then it should work after all the alcohol has evaporated if it was ISO
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
some thermal paste is electronically conductive. It could have killed it from some thermal paste getting in the socket. Rubbing alcohol is completely non conductive and evaporates quickly anyway. I dont believe that would have killed it. Is it possible that you accidentally bent some pins into each other?
Build:
Intel Core I7 6700k (clocked to 4.6ghz)
Patriot Viper 3000mhz ddr4
ASUS maximus 8 hero (I hate this mobo)
Evga gtx 1080 superclocked
250GB Samsung 850 evo
2tb WD Black 7200rpm
Ek watercooling kit a240g with 360 expansion pack
Primochill Vue Red fluid
Corsair Graphite 600t (white)
You thought "Gee, Donald Trump sure has a great build!"
8 minutes ago, Irekski said:
I used 70% ethyl. I did not notice any thermal paste or probably it was liquidized thermal goop... Hmmm mobo alone is not turning on is it possible the only mobo got damaged? Some black spots on my cpu pins probably caused by arcing
Use contact cleaner instead of ethyl next time.
Some thermal paste is conductive. You might have killed your cpu or motherboard. Also, 70% ethyl might not have been high enough concentration. Some water could've been left behind.
Troubleshooting steps:
Try your cpu in another motherboard
Try your motherboard with another cpu
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
Spray 100% alcohol and blow them dry...might work...xD...I did clean my cpu with 99.99%alchol and blast them with air before putting back...it might just be the compressed air that cleaned the parts...😅
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
1 minute ago, Irekski said:
With the current lockdown on my area i dont think id be able to find any 100% alcohol right now
Where are you from? Over here we can order online...but it's overpriced..because some people get the 100% and dilute to 70-80% for sanitizing...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
