I am having issues cooling my new build under heavy load. I recently discovered my issues in staying cool when trying to setup folding@home. I have an all core overclock at 4.2ghz at the stock 1.3v and undervolted a lot of the other recommended items to attempt to deal with heat. I didn't have any luck with that so I took my cooler off and replaced the stock pre-applied thermal paste with some thermal grizzly. That didn't seem to help either so I replaced all my stock case fans with Noctuas as well as adding two more on top of the default three. I also switched my rad fans to Noctua NF12s and moved my rad from a push config at the top of my case to a push config at the front of my case pulling fresh outside air. So far throwing money at my issues has not helped any so I am coming to you guys for help. I have done my research and I shouldn't have this much trouble keeping my 3950x cool with this cooler compared to other people, and most of people I found with issues similar to my own were running much higher voltages than I am. I reached these temps after about a 5m stress test, I am quite confident they would keep climbing had I left it running. Ambient temperature roughly 24c. Thanks in advance. If anyone would benefit from a screenshot of my BIOS OC profile let me know and I will supply it.
https://linustechtips.com/topic/1197662-3950x-thermal-issues/
1.3V is not considered undervolting for 3rd gen Ryzen, in fact it's a higher voltage than I would recommend.
This is a good read on voltage issues with the new Ryzen CPU’s: (And why I recommend low voltage)
https://www.reddit.com/r/overclocking/comments/ejd5c9/1325v_is_not_safe_for_zen_2/
I'd recommend adjusting your voltages as follows:
-          CPU Core Voltage – Manual Mode – 1.2500V (offset mode if you want to get into more fine tuning)
-          CPU SOC Voltage – Manual Mode – VDDSOC 1.1000V
-          1.8V PLL Voltage – 1.8000V
-          1.05V SB Voltage – 1.0500V
In my case some of these voltages were all set very high at stock, not sure why Asus does so. For safe stock operations this is recommended. 3rd gen Ryzen performs best under cool temps, so lowering the voltage to 1.2500V is safe and best for long term use.
I have improved system stability and overall performance while lowering temps with my R7 3800x following this method. And my CPU can now sustain max boost speed for longer because of the lower temps.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1197662-3950x-thermal-issues/#findComment-13626074
Thanks for your recommendations, as per your suggestions I did the following:
Lowered my all core overclock from 4.2ghz to 3.8ghz as I did not think 4.2ghz would be stable at 1.25V
CPU Core Voltage from 1.300V to 1.250V
CPU SOC Voltage from 1.125V to 1.100V
1P8 Voltage from auto to 1.800V
As for SB Voltage, I am not sure what MSI calls this in their BIOS as I did not see it so this did not get changed.
Saved my changes and attempted to post and failed. I am unable to get to my BIOS
According to my motherboard LEDs I achieve the following:
SEC Progress Codes
01 Power on. Reset type detection (soft/hard)
02 AP initialization before microcode loading
03 System Agent initialization before microcode loading
04 PCH initialization before microcode loading
06 Microcode loading
07 AP initialization after microcode loading
And then I am stuck on 07 without further initialization
My CPU debug LED is also lit up indicating CPU not detected/fail
Resetting my CMOS did not appear to do anything other than reset all my custom fan curves.
https://linustechtips.com/topic/1197662-3950x-thermal-issues/#findComment-13627967
Alright, I succeeded in getting my PC back. CMOS reset didn't seem to work fully the first few times I tried it, reset my fan curves but not anything else. A combination of leaving the computer unplugged for longer and shorting my CMOS for 20s instead of 10 seemed to fully reset it. Back to the glorious stock motherboard settings including a lovely CPU voltage of 1.481v. Will see if I can successfully alter my voltages without killing my system again.
https://linustechtips.com/topic/1197662-3950x-thermal-issues/#findComment-13628317
How is the CPU block oriented on the CPU?  My AIO works best (on my 3900X) when the block is oriented with the tubes at the bottom of the block.  While I'm pretty sure your AIO isn't an Asetek it probably behaves similarly ie orienting the coldplate/block for better coverage of the CCDs.  Also, double-check you're using enough mounting pressure.
For Folding I've found I can run my CCD 1 at 4400 and my CCD 2 at 4250 with 1.2625V with the second highest LLC setting.  That gets me into the low to mid 80s with my 12 cores.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1197662-3950x-thermal-issues/#findComment-13628510
Here is an HWiNFO screen during a CPU Folding work unit running to completion.  Ambient room temp ranged from 75*F ~ 80*F.
https://linustechtips.com/topic/1197662-3950x-thermal-issues/#findComment-13628661
