Recommended settings for Anno 1800
Solved by Darkseth,
Just buy it, and find out.
It should be more CPU intense later on (when alot stuff is going on).
However, noone knows how much fps is enough for you. Some people are perfectly fine with 30 fps, others need 60 fps or they get an epileptic shock
At the worst: You can reduce settings to medium or even Low (or even Drop resolution as the last measurement). But you should easily be able to play the Game.
You can upgrade your Hardware later anytime. Don't miss a good Sale/deal for a Game you want to enjoy, just because of the Hardware today ^^
