NzxT AMBIENT LIGHT Makes annoying noise.
Redoga
hello i recently buy an NZXT ambient light and notice if i change the light from spectrum wave  the power supply makes a buzzing sounds from where its plug in. i can't Return it due to tossing some of the stuff came with it ETC different region socket adapter. is this  a cause for concern the noise it makes
