Hi
I built a gaming rig recently and I'm stuck near the router in my living room and I'd like to move it to my room, so I'll need wifi, I don't wanna go over the hassle and get a 30m ethernet cable and try to route it, probably would be too messy.
I currently have 3 free pci slots one is 16x , maybe a pci wifi card? or a usb one?
thanks in advance
https://linustechtips.com/topic/1197018-wifi-solutions/
tp-link AX3000 is the best one i found. includes wi-fi 6, and bluetooth 5.0
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13621156
1 hour ago, Malymole said:
If you're looking for a cheaper, but still really good quality, TP-Link Archer T3U AC1300 MU-MIMO USB 3.0 WiFi Adapter would be a good option. I don't think you need a proper router, and I game with this specific dongle with no issues
yea but I thought I'd make use of the PCI slot since PCI 'should" be better than usb wifi since its directly linked to the mobo and has more connections , and possibly better hidden antennas.
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13621387
1 hour ago, limeington said:
im pretty sure usb wifi is slower than pci wifi
It's cheaper, and for gaming you don't really need speedy wifi, as the most important factor is ping. This USB adaptor is more than capable of running the maximum wifi speeds of a regular household, and has a very good ping rate, and high speed pci network cards are usually used for transferring data locally, not from your network provider
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13621392
4 minutes ago, Bruh1 said:
but this is a router I'm looking for a PCI card to put in the motherboard so I can have wifi on my PC I already have a decent router.
Bruh...
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13621398
Just no.
USB networking products have a tendency to be slower and have poor cooling. They tend to overheat and stop working after a while. PCIe cards tend to be faster and in some instances have better range. Also PCIe cards from my expirence are more reliable. Ping has nothing to do with PCIe vs USB. Ping has to deal with how congested the airwaves are and how much crap the WiFi signal has to travel thru.
Id go PCIe. Look for a wireless AC (WiFi 5) card or greater. Id probably suggest using something like WiFi analzyer on your phone to check the airwaves and check the signal at the location your trying to install the computer first. As long as you have decent signal and the airwaves are not too congested you should be fine on most games. Competitive FPS's might be a challenge because the fact is WiFi has higher latency and there is nothing you can do about that.
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13621784
This is not the time to be lazy. Invest some effort now and you'll save yourself loads of time, effort and frustration in the long run; sure it may take a day to set up and require some drilling in a ceiling or whatever but it's going to be worth it in the end.
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13623270
its not really all about lazniess but mainly cause my apartment is rented so I don't really feel comfortable drilling that many holes to route a cable across the thing , but i don't know.
https://linustechtips.com/topic/1197018-wifi-solutions/#findComment-13632756
