HELP!!! RAM Up gradation
Solved by SpookyCitrus,
1 hour ago, MKGSuperSaiyanBlue said:My motherboard is Gigabyte GA-H110M-S2 Socket LGA 1151 Motherboard
Yes it will support it however, the motherboard only supports up to 2400mhz speeds, so it will not use the full 3200mhz of the new ram kit.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
