yes,
when opening sound settings, down at the bottom is advanced sound settings.
there you can set the sound device per application.
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
Thank you so much dude that did help with that problem, but I do have another question. How do I get more apps to pop up it only shows 3 right now? Chrome,Razer, and system sounds, but I was hoping to get youtube to play on headset while hulu play on the other for my wife. Thank you so much!
in order to set them, the application has to send an audio signal, soon as it sends that it should pop up there.
