My cpu is running at 60-70 degrees celsius idle, and high 80's while playing basic games. I have reapplied thermal paste, made sure my cooler is all the way on, all my other hardware is normal termperautre. I have a Ryzen 5 3600 and really need help because I feel like I have tried everything in terms of trying to get it to cool down and nothing is working
https://linustechtips.com/topic/1196124-need-help-cpu-running-extremely-hot/
what is your room temperature? normally if you are in a hot country, that kind of temperatures, especially on the stock cooler is kinda normal
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
Those temps are about right for Ryzen chips from my experience. My 3800x idles at 52c even though its attached to a 140mm AIO. If you have PBO enabled and your motherboard has the overclock enhancements enabled (some do by default) you can turn those off to reduce temps.
42 minutes ago, Ry23n1 said:
Im using the stock cooler. Idling it is consistently pretty hot
Those are the normal temperatures for a Ryzen 5 3600 in a bad case in a warm room when using the stock cooler.
Zen 2 produces a lot of heat, and that stock cooler the 3600 comes with is plain bad.
Any AM4 compatible tower cooler with a few heatpipes and a fan of 92mm or larger would solve your temperature problems.
The cheapest I'd go would be the Snowman cooler from AliExpress. Or one of those better Wraith coolers (like the ones that come with the 2700X).
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
You probalby have a bad ventilated case. ¨try to add more fans on the case or/and get a better cooler
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
