Yes I think so. For saftey just plug the drive out when you do it if you can.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1195750-help-me/#findComment-13611288
It may not be necessary but I always unplug other drives for a new install, just "feels" right.
I ensure it is clear of all files AND my important files have a known good backup (Essential at all times IMO).
Then its just install the OS, then plug back in the other drives and start remapping the user and steam folders etc (they are all on the other drives, the boot drive only had OS on it and no user folders before starting).
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1195750-help-me/#findComment-13611293
Then its just install the OS, then plug back in the other drives and start remapping the user folders etc.
I just have one 500 gb hard drive divided into c drive and other drive. To make sure should i make a backup of my files in G-drive? is it safe? Will it erase c drive with other drives like "d" or "F" ?
https://linustechtips.com/topic/1195750-help-me/#findComment-13611299
14 minutes ago, xtriz200 said:
PLZ HELP!
Please calm down. Lots of people aren't even awake yet, and you are not entitled to free answers, especially answers that can easily be found with a Google search.
Back up all of your files to an external drive, and completely wipe your hard drive. Having it formatted in two partitions does not provide any benefit, you should simply have a single drive formatted as your boot drive. It is too easy to accidentally erase unintended partitions when trying to keep a single.drive divided.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1195750-help-me/#findComment-13611365
Thank you man! i am Asian so... Yea.
https://linustechtips.com/topic/1195750-help-me/#findComment-13611367
