So i just got my shiney new 3950x and a asus prime x570 pro motherboard, i noticed that when i put the CPU under load it throttles down to 3ghz (sometimes 2) and core voltages drop to 0.95.
before you go is this person stupid, it never goes past 60 degrees celcius, i have the 8 pin plugged in, i have updated chipset drivers and bios to newest versions, i have tried disabling precision boost and re enabling it, i have tried using a different cooler (although that doesnt seem to be the issue) and i have tried re installing windows on 2 different drives, its the weekend and i cant get hold of AMD or ASUS customer service till monday. does anyone have any ideas of how to fix this other than manually setting core voltages
CPU: 3950x
GPU 980ti
PSU: Corsair TX 750M
MB: asus prime x570 pro
Cooler: Corsair h100i PRO XT
RAM: corsair vengance LPX 16GB 2x8 2440MHZ (for some reason even with AMDs XMP clone enabled it stays at 1168MHZ)
** UPDATE **
so someone told me to manually set the core voltage to 1.3 and the base multiplier to 40 (4ghz) this has worked and now i dont get any stupid throttling but it would be nice for a more permanent solution. Thanks to everyone that helped me and if you know of a more permanent fix i would greatly appreciate it if you could pop it in the replies.
https://linustechtips.com/topic/1195009-3950x-boost-problems/
Use a resource monitor like HWinfo, not task manager.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1195009-3950x-boost-problems/#findComment-13606116
Make sure that Core Performance Boost is Enabled and PBO is set to enabled. I'd load BIOS defaults, set those two options and see what happens when it reboots.
Maybe update BIOS if you can in case it's not got the right patches. ABBA 1.0.0.4B is the latest and recommended patch I think.
Do not manually set the core voltage. Let the CPU do it's thing. Especially at factory clocks. Sure it looks scary sitting at such a high voltage given the silicon but AMD knows what they're doing.
If you want to manually set the voltage then you should also manually overclock it. You might lose a bit of single thread performance but gain quite a bit of multi core performance.
https://linustechtips.com/topic/1195009-3950x-boost-problems/#findComment-13606120
1 hour ago, InfinityVive said:
I may sound stupid but it happened to me before, I once plugged PCI 8 pin connector to CPU's 8 pin connector, Somehow the notches matched and it got plugged it, the PC booted up but my CPU had the same problems as yours, are you sure you got the CPU running on CPU 8 Pin connector and not PCI 8 Pin connector?
it has CPU printed on the side of its connector and its a fixed cable in my semi mod PSU so its the right one
https://linustechtips.com/topic/1195009-3950x-boost-problems/#findComment-13606336
