I have been having this problem since I bought my PC. 2007. I am not able to fix it anyway. I tried a fresh install of windows, graphics driver, and directx also. It is still showing the same thing in each and every thing. From nfs to epic games launcher. I can't even download gta 5 because of this. Epic launcher wouldn't even open.
Please help me, please 🙏🙏🙏
https://linustechtips.com/topic/1194877-please-please-help-me/
Try running a check disk command in Windows and if that fails then you'll have to uninstall "Epic Games Launcher" from add/remove programs in the Control Panel and then install it again.
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13604956
Try installing all the Visual C++ Redistributables, you can get an all-in-one installer from https://www.techpowerup.com/download/visual-c-redistributable-runtime-package-all-in-one/.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13604970
Also you can log in via the website and put the game in your library to be installed later.
https://www.epicgames.com/store/en-US/product/grand-theft-auto-v/home
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13604975
Can I really run gta 5 though ?
I have pentium g2030 dual core at 3 GHz
4gb ram 1333 MHz
Nvidia GeForce GT 710
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13614093
Ram is 4gb 1333 MHz
2gb nvidia GeForce GT 710
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13614094
The 2005 files are not being installed. It's showing this error. Will it be a problem ?
And all other files have been installed, but it is still not working. Still the same problem.
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13614544
4gb ram 1333 MHz
The minimum requirements for GTA 5 include a quad core CPU (Intel Core 2 Quad Q6600 or AMD Phenom 9850 at the minimum), 4GB of system RAM, 65GB of available disk space, and a Nvidia 9800 GT 1GB or AMD HD 4870 1GB (at the minimum).
Your graphics card should be sufficient to be playable, 4GB of RAM is on the low side (would recommend upgrading to at least 8GB of RAM) although should work, and the CPU is definitely going to need an upgrade to a quad core or better. Is this a pre-built system or a custom-built system, you may be able to upgrade keeping some components same (case, storage, fans, possibly power supply, etc) although will need to upgrade your motherboard platform and processor (also may need new RAM since your current 4GB of RAM is DDR3 and modern standard for computers today is DDR4)?
If you would like some recommended upgrades, please state your components list (include case, power supply, motherboard, etc) and budget for upgrades within this thread.
        @Boomwebsearch
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13615459
2005 shouldn't matter, it's rarely used nowadays. If the issue is still occurring, try running Microsoft .NET Framework Repair Tool from https://www.microsoft.com/en-us/download/details.aspx?id=30135. If this doesn't help, the issue likely originates from a hardware failure.
Desktop
Homelab
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13615481
Well, I am not in a condition to build a new pc as of now. This was my custom build back in 2007. And also, I accidentally shorted out the fan connection on the motherboard so the fans are connected to an external adapter. The cooling is all right though, there are 3 extra fans in my system. And my motherboard can support max an i7 3rd gen. And yes ram is DDR3.
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13617781
Okay, what memory configuration are you using on this system to get the current 4GB of total system memory (1x4GB, 2x2GB, 4x1GB, etc)?
Any LGA 1151 socket quad core CPU should work fine, would strongly suggest going used or refurbished component upgrades since the new ones are unreasonably expensive more often than not.
        @Boomwebsearch
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13619073
a quick google search shows its a .net framework issue, sometimes windows doesnt come installed with it from the get go.
it does it in a later update.
try running windows updates.
if not then try control panel then , add and remove features and add .net framework
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13619102
i am using 2X2GB config.
and i am trying to get my hands on a refurbished i7-3rd gen but it is proving very difficult to get one because people who have got this kind of cpu never go for top end. and i have a 450W psu. will it be fine for the i7 ?
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13622252
i ran the repair tool, it did the following changes:-
a. it rerun the windows installer
b. and another like this i cant remember
still epic games launcher is not running. same error. would the error be something related to directX ?
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13622265
i installed .net framework 4.5.2 manually. i also ran the repair tool for it but i still cant get it to work. the epic launcher is still saying the same 0xc000007b error.
is there any other way i can play gta 5 on my pc ?
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13622269
Assuming that the following video is correct, there shouldnt be any issues with your hardware that stops you from running epic games launcher.
so its definitely software related.
when installing .net did you experience issues doing it through add and remove features option? since you wrote that you did it manually.
what version of the windows 10 update are you on? i think 1909 is the latest.
Also have you run windows update?
https://linustechtips.com/topic/1194877-please-please-help-me/#findComment-13622645
