Budget (including currency): 1200$ (USD)
Country: india
Games, programs or workloads that it will be used for: Valorant, Cs:go, doom eternal, apex legends, Minecraft, ds, 3ds, wii/gamecube emulator, video editing and light streaming.
Other details : as I said this is my first PC build and I do not know which parts to buy I want a AMD based system with rtx 2070 super the build can go slightly over the budget with a windows copy. The budget is only for the PC parts. Also not too much RGB plz reply any help will be highly appreciated.
https://linustechtips.com/topic/1194674-first-pc-build-need-help-plz/
I'm working on a parts list but I have 3 quick questions:
  1. Do you want a motherboard that supports the next generation of Ryzen CPUs?
  2. What kind of part availability do you have in India? I can meet the budget in USD but I have no idea what parts would or wouldn't be available.
  3. How soon do you need this?
Country: india
Wait for a few months when ryzen 4000, geforce 30xx, and b550 come out.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
If you're at 1080p you should be good with a 2060 super. I couldn't spec out a build with the 2070 super without cutting corners in other areas that I personally wouldn't recommend.
Country: india
you're in india, give us your budget in rupees.
Well I didn't see a reply so I assumed you wanted it right now, you don't care about next gen Ryzen support, and you have decent part availability. I was able to get a 2070 Super in it with almost no RGB! (almost all motherboards have some...sorry). Here's what I'd get:
A few notes:
  • I just put $15 for Win 10 Pro OEM cause that's the most I'd expect you to pay on eBay or a number of other sites (which is what I'd recommend doing, unless you have a Win 8 or even Win 7 key lying around as they'll likely work just fine)
  • The Ryzen 6 3600 stock cooler is pretty good but a bit loud. If you want it a bit quieter, the one @Sorenson recommended is a decent option.
  •  Frankly, if you can I’d probably wait at least a month or two for B550 (which will at the very least likely make B450 cheaper) or until the next gen Ryzen professor come out if you can stand it that long
A few notes:
I realize after looking at yours that I could have totally fit a 2070 super in, I just thought the 2070 super was way more fore some reason.
The one I put in is definitely on the cheaper side of the 2070 Supers. I personally think the EVGA ones are the gold standard but they cost a bit more. But unless they need this system right now I’d wait a few months anyways
Yes please next generation rysen also
I can get 90% of parts here a little more expensive though
And I don't have a rush as my current laptop is kind of working
How soon do you need the computer? If you can wait 4-5 months you can probably just get the next gen Ryzen (instead of just have it be compatible and likely the next generation of GPUs from Nvidia and maybe AMD too.
Oh OK thank-you alot for telling me about this
Sure thing! If you can wait that long, I definitely would. At minimum it'll mean all the current stuff will get cheaper as well. By Christmas I expect:
  • AMD Ryzen 4000 series CPUs (and X670 chipset with it)
  • AMD B550 Chipset (this is already "out" but nothing is actually shipping with it yet)
  • Nvidia 3000 series GPUs
  • Maybe AMD "Big Navi" GPUs
Also when the 3000 series gpus comeme out which should I get or should I get like a 2080 if it gets cheaper.
Hard to make that call right now. The 2000 series ones will certainly come down in price but it's hard to say by how much
I am assuming your budget is around 90,000 INR to 100,000 INR
Like others have mentioned here, it's better to wait for new RTX 3000 series GPUs and new Ryzen 4th Gen processors, either the price of components will decrease or you'll get better performance for same price
But if you don't wanna wait, I would recommend the following components
  • Ryzen 5 3600 CPU
  • X570 Motherboard, either ASUS TUF GAMING X570 PLUS (Wi-Fi) or MSi MPG X570 Gaming Edge (Wi-Fi)  (you'll be able to upgrade to Ryzen 4th Gen in the future if you go for a X570 Motherboard), you can also get a cheaper X570 motherboard and use the money saved for a better SSD or GPU
  • RTX 2060 Super GPU, or if you can spend some extra money by cutting corners else where, go for an RTX 2070 GPU
  • Corsair Vengeance LPX 16GB (8GBx2) 3200MHz DDR4 RAM or G.Skill Ripjaws V 16GB (8GBx2) 3200 MHz DDR4 RAM
  • 480 GB SATA SSD (Adata/Samsung/Crucial/Western Digital/Intel), or an M.2 NVMe SSD (if your budget allows, great performance)
  • 2TB 7200 RPM HDD (Barracuda, preferably), if budget is tight, go for the 5400 RPM version
  • Antec Dark Phantom DP501 Case
  • Corsair/SeaSonic 600W or 650W 80+ Gold Rated Fully Modular Power Supply, Antec power supplies offer higher wattage for same price, but i don't know about their performance
Websites to buy from (all based in india) -
