Even I am obsessed with a case without window and I use a Corsair case. Sure, there are a lot of high quality cases in the market and your pick of Fractal Design Define R5 is certainly one of the best cases available in the market. I’d like to suggest a few to your list and I hope this is useful in some way or the other.
Corsair Obsidian 1000D, Fractal Design Meshify-C, Nanoxia Deep Silence 4, NZXT H200i, and Phanteks Evolv Shift X are also some of the best cases without window and I think these are available even in Australia, so it should not be a problem for you to buy one from this list.
40 minutes ago, Scotty4009 said:
Does that one have a cd slot?
If you're referring to a 5.25" bay where you can insert a CD or DVD drive, it does.
22 hours ago, Scotty4009 said:
What makes that one a good option?
Price to performance. It's not a super feature packed and amazing build quality, but it's cheaper, and that was the criteria. I couldn't find the Define R5 so I'm not sure how much less I should be looking at price wise to stay under.
