I am planning on repasting my laptop as it is outside of its warranty period now and figured it might help drop temps a bit. Plus I've heard factory thermal paste is garbage. I was just wondering what would be a good thermal paste to get? I've looked around the web for a while and a lot of people suggest Kryonaut and MX-4. I've also heard that some thermal pastes tend to dry out due to the different mounting pressures that laptops have, so I want to know for sure if I get something like Kryonaut, will it make a good enough difference to be worthwhile? And if so, will it last at least a year or two before needing to be replaced? And for the record, yes I know that it probably wont make a massive difference (probably no more than 3-5 C), but like I said, it is outside of its warranty and I have the money to burn so why not. If you need my specific laptop, it is a Predator Helios 300 PH-315-51-78NP.
MX-4: will dry out fast in many laptops
Kryonaut: only works well in good heatsinks aka heatsinks with relative flat and even mounting pressure
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
