2 minutes ago, Kiko Sousa said:
My pc randomly stopped booting up can somebody help me?
Please list your system specs and any additional details of the issue so that members can assist you best.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588065
Also, please be honest about what you did recently.  Did you move the PC?  Open the case to check something?  Download anything, even if you think it was no big deal?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588072
What is happening exactly?
You press the power button on your PC.. And then?
Any lights, fans spinning, noises, etc.? Does it turn on and then off again? Anything on screen? Or does it just not show anything on screen?
You probably would need to perform the PSU test.
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588073
Specs: i7- 930, 16gb of ram , gt430 graphics card, intel motherboard, hdd and ssd and a corsair tx650 power supply
When i turn it on it starts beeping and it doesnt post.
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588098
the only issue i can remember is when i ``kick´´ the pc accidentally it shuts down.
the only thing i did now was open it to check if something was loose.
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588111
the fans turn on it starts beeping and doesn't post at all.
What is that test ?
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588128
Try to reseat ur ram .... it's fairly easy.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588158
What is that test ?
5 minutes ago, Kiko Sousa said:
How do i do that ?
You remove the ram from your motherboard and then you place the RAM into your motherboard again.
Basically you open the case up, look at the RAM, unclip the sides of the RAM, take out the RAM and then insert it back into the board again (until you hear it click shut).
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588251
Oh ok i thought it was something bios related. I did that now and unfortunately the result is sitll the same .
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588280
can u try 1 ram stick at a time ?
did u reseat the ram it properly ?
are all the motherboard power connectors plugged in ?
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588527
13 minutes ago, Kiko Sousa said:
it worked once and now it doesnt again.
which ram stick didn't make the computer boot ?
remove that ...
and everything should be gd ...
if it's not a ram issue then most probably RIP motherboard
https://linustechtips.com/topic/1192609-help-plz/#findComment-13588669
remove that ...
I got it working when i removed a ram stick from the 6th slot so its either the ram stick or the slot that is dead .
https://linustechtips.com/topic/1192609-help-plz/#findComment-13591383
most probably the ram stick ...
so it works now ?
https://linustechtips.com/topic/1192609-help-plz/#findComment-13591424
