I bought an NH-D14 and I also bought  Arctic Silver 5 Thermal Compound 3.5 Grams
I did not know, but the NH-D14 came with it's own thermal paste
Which one of the two should I use?
Here are the links:
http://www.amazon.com/dp/B002VKVZ1A/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=1RET534YUU3QQ&coliid=I3FVHWLA1OSA5S
http://www.amazon.com/Arctic-Silver-Thermal-Compound-Grams/dp/B000OGX5AM/ref=pd_bxgy_e_text_z
https://linustechtips.com/topic/119144-thermal-paste-question-please-help-me/
Whichever you want, there won't be much difference. (~2 degrees?)
All CPU coolers tend to come with their own. Just keep your Arctic silver to one side and use it whenever you need to change the thermal paste in anything.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
The aftermarket thermal paste is better.Make sure to clean its surface with alcohol REALLY good before applying
 C++,Assembly,Reverse Engineering,Penetration testing,Malware analysis
Do you have a question?Are you interested in programming?Do you like solving complex problems?Hit me up with a pm.
the arctic silver will probably be a bit better, though Noctuas paste is really good also.
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
alcohol on what? q-tips or just paper, towel, idk I really don't want liquid near my pc im new sorry :S
Put a really small ammount on your towel and smoothly clean it.I suggest a smooth towel,you don't want to damage your cpu cooler.Make sure to completely remove it when you are done!
Real 99% isopropanol alcohol is not conductive. So it is no problem to use it. And I amusing Noctuas paste for years now. I is relay god. Maybe the silver will be 1-2°C colder...
Use the paste you like it does not matter
The good thing with noctua is that all their products come with their own fans and thermal paste, no crappy OEM stuff. Noctua paste'll do you fine. I also believe it's non conductive unlike Silver 5, so if you're worried about shorting I'd use the noctua
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
both should be fine use the noctua one first and if you messed up or change out your cpu in the future use the artic silver i use it and really like it
its GE (pause) TechNicks
my rig plus everything i have bought for it http://pcpartpicker.com/p/30sNV
