Macbook Air (WIFI) and PC (ethernet over power) file sharing
mikber
Hi Guys,
Is there a way to file share between my machines in the setup above?
PC - Eternet over power adapters
Macbook Air - WIFI.
Or is the only way of achieving this is both of the machines on WIFI?
Thanks
Whether your machine is connected to your Network via WIFI or PowerLAN does not make a difference.
Interface type doesn't matter, what's needed is for all to be on the same network.
F@H
GPD Win 2
are they on the same network? If so you just share a folder on the PC or allow file sharing on the mac, and just connect over the network..
If they're not on the same network, the easiest method is something like dropbox.
🖥️ Motherboard: MSI A320M PRO-VH PLUS  ** Processor: AMD Ryzen 2600 3.4 GHz ** Video Card: Nvidia GeForce 1070 TI 8GB Zotac 1070ti 🖥️
🖥️ Memory: 32GB DDR4 2400  ** Power Supply: 650 Watts Power Supply Thermaltake +80 Bronze Thermaltake PSU 🖥️
🍎 2012 iMac i7 27";  2007 MBP 2.2 GHZ; Power Mac G5 Dual 2GHZ; B&W G3; Quadra 650; Mac SE 🍎
🍎 iPad Air2; iPhone SE 2020; iPhone 5s; AppleTV 4k 🍎
as long as the wifi is part of the same "network" (ie same router) that the ethernet is connected to, both machines should just be able to see each other as long as you're putting in the correct IP address of the ethernet adapter in the connect to server window on MacOS (command+K). Making sure it's in the right format of
smb://192.168.0.20
or what ever the IP is of your PC
