Anyone know if this is compatible with Gigabyte 2070 super oc windforce 3x 8g, it should be also compatible with cooler master h500p, not sure.
https://www.coolermaster.com/catalog/cases/accessories/vertical-graphics-card-holder-kit/
Because seller isn't sure and said it was made for 1000 series gpu. So i don't buy it and than it doesn't work. And coolermaster forums are dead and nothing on their main website about this...
https://linustechtips.com/topic/1190697-vertical-gpu-mount-for-2070-super/
It is a universal three slot bracket, so it should work with any GPU. The 2070 Super Windforce 3x from Gigabyte is a two slot card so it should work fine. GPUs are universal, it doesn't matter between GTX 1000 and RTX 2000 or even AMD's RX line, they should all have the same mounting only differences will be how thiccc the card is, one slot, two slot, three slot, if it's a mini so it can fit in ITX cases, that sort of thing.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
