[HELP] Ryzen 5 1600 with b450m S2H 3000Mhz or 3200Mhz?
Solved by boggy77,
yes. most important is to have 2 sticks of ram, so they run dual channel. the difference between 3000 and 3200 isn't much, and ryzen 1000 series struggles anyway to run it at 3200, so if 3000 is cheaper, go for that. make sure the timings are decent as well. C15 or C16, not C19.
Featured Topics
Jakubman625 ·
Posted in Troubleshooting3 -
1
7
2
Millios ·
Posted in Graphics Cards20 -
1
tall_goat_2 ·
Posted in New Builds and Planning2
