Hi guys i just have built my new pc and when i try to install the drivers and restarting it,the drivers dosent seem to show up like the amd or realtk  and i keep downloading and restarting and nothing happens. I am thinking of buying a cd reader maybe i can install the drivers from the cd in the motherborad box.
thank you
https://linustechtips.com/topic/1189796-motherboard-drivers-problem/
thank you
windows should just auto install everything you need when you get it online. cant remember the last time i needed the included disks
The motherboard drivers are not going to show up in the doc. If it installed successfully then they installed. Also do not use ones off the disk. Those are generally very out of date.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
