Posted May 5, 2020 Hi everybody I'm a photographer and graphic designer living in Ecuador. I currently have an i5 4460 paired with 8 gb of ddr3 1600 ram without any graphics card. I just saw a gtx 980 for sale for 70 USD, which is a pretty good steal, but I'm wondering how much I'll benefit from adding this to my system. The powersupply I have is a Thermaltake TR2 430 watt. I use Illustrator, photoshop and lightroom, along with the occasional premier pro and after effects. I do not game. Will I see any benefit from adding this videocard to my machine, as in gpu acceleration for any of the adobe suite programs? And will my PSU be enough for this card, once again, not being used for gaming. thanks in advance. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2020 5 minutes ago, KevinVH90 said: The powersupply I have is a Thermaltake TR2 430 watt. I think this power supply only has one 6 pin PCIe connector, so you can't actually use a 980 with it. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. How many watts do I need? ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained, group reg is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2020 Author 4 minutes ago, Fasauceome said: I think this power supply only has one 6 pin PCIe connector, so you can't actually use a 980 with it. damn, I just checked, you're right. There's no way it'll work with just the 6pin? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 5, 2020 You would need at least 500-600 power supply regardless of the connector available. Magical Pineapples
