Hello
I was wondering since I dont have any internet connections to my main computer because all the drivers are broken idk how to fix them.(code 10) with my ethernet drivers and my internet drivers arent even showing up.
So i was just wondering if I bought a usb to ethernet adpater would actually provide me ethernet.
Specs;
motherboard: asus rampage v extreme
gpu: rx 580
cpu: i7 5820k
ram:16gb ddr4 2400mhz
https://linustechtips.com/topic/1189088-usb-to-ethernet-adapter/
sounds like solving the symptoms, rather than solving the problem.
look up which drivers you need to use for your network adapters, download them, and transfer them to the problematic system with a usb stick.
12 minutes ago, ali_alper said:
Hello
Specs;
gpu: rx 580
cpu: i7 5820k
I agree with downloading the drivers from Asus and reinstalling first.
You could clean install windows, or try to reinstall your ethernet drivers from a USB drive by using another computer to put them on a USB.
A USB to ethernet adapter would also need drivers, so unless it comes with a CD or something you still need an internet connection for windows to get the right drivers.
I have already uninstalled the drivers and reinstalled them about 3-4 times now.I have also clean reset my pc about 2 times but I just can't seem to get the drivers working.
The photo underneath is the driver that I am having problems with.
I have done what you said about 3-4 times in the past but still nothing.
Here is the driver that has the problem maybe you can help.
How did this happen to begin with?
Are you having problems with other drivers?
Can you afford to reinstall Windows?
I was playing a game and suddenly the pc gave a blue screen. I restarted it via the power button and my mouse and keyboard were not being detected. I went into the bios and changed the "xHCI" setting to disabled (this decision came based upon a forum reply to someone who was having the same issue) and the peripherals started working again. But now the wifi adapter and ethernet were both not working as I stated before(code 10). To answer your question, no other drivers are presenting an issue and I have already reinstalled Windows 3 times so I have no idea what the issue may be. Thanks in advance for any responses.
