Hi everyone,
I'm starting with Scratch with this script to draw triangles wich so far I made it correct, but now I would like to improve my script by setting to change side length by 10 everytime a new triangle is draw. Eg: set to draw one triangle side length will be 10; set to draw two triangles first will have sides length 10 and second will have sides length 20; set to draw three triangles first will have sides length 10, second will have length 20 and third will have length 30; and so on…
The next triangle will be drawn 20 steps away from the top corner of last triangle
I have tried setting side as a variable but never made to change side properly, if anyone could amend my script would be great please!
Script below:
define sides
move (10) steps
when [space] key pressed
set [no of triangles] to [3]
repeat (no of triangles)
  pen down
  turn ccw (60) degrees
  sides
  turn cw (120) degrees
  sides
  sides
  pen up
  sides
  move (20) steps
  turn cw (60) degrees
end
https://linustechtips.com/topic/1188591-help-with-scratch-simple-draw-triangle-loop/
