PC upgrade advice
Solved by Fasauceome,
5 hours ago, Andrew Phan said:Thanks, instead of buying the ram, could I just re-use my current 16gb Corsair vengeance 2400 as I recently purchased these or are they not compatible?
Compatible, but might not provide very good performance, so you should buy the Ryzen CPU and motherboard, see how the performance goes for you, and then once you sell your current stuff you can buy new ram with that money if you need it
