Like can I聽put it on the front of my case and expect the same performance as if I put it on top or in the back? Or is there an ideal location to mount AIOs? 馃
CPU:聽i7 8700K (5.1聽GHz OC). AIO: EVGA CLC 280 280mm.聽GPU:聽EVGA XC2 Ultra 2080Ti.聽PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE.聽RAM: 32GB聽Corsair Dominator Platinum RGB聽(3600聽MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO,聽1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue.聽CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz.聽Headset: Steelseries Arctis 5 Gaming Headset.聽Keyboard:聽Razer Cynosa Chroma.聽Mouse: Razer Basilisk Ultimate (Wireless)聽Webcam:聽Logitech C922x Pro Stream Webcam.
https://linustechtips.com/topic/1187094-does-aio-location-matter/
It's not so much the location as opposed to whether it is intaking or exhausting air. Assuming of course the two locations have an equal access to air (impedance), if one location is blocked off by TG, and another is meshed, then the location will matter.
If you are intaking air, while it has access to cooler air outside the chassis, it will be sending warmer air (how warm depends on how efficient the radiator is, and how hot the CPU is) towards the inside the chassis. This will negatively affect the temperature of components in the chassis (normally the GPU).
If you are exhausting air, the heat from the CPU is removed directly from the chassis and thus does not affect negatively the other components in the chassis. However this means that it has to use the air from inside the chassis to cool the radiator and so if your chassis internal temperature is warm, due to having a open shroud GPU for example, the CPU temperatures will suffer.
"Heat rises so you should....." types of advice are almost myth-class unreliable since active airflow in the form of fans negate most of convection/radiation based cooling. Front intake, front exhaust, top intake, top exhaust, rear intake, rear exhaust, each have their time and place.
