I'm trying to incorporate RTX voice on my work laptop. with only integrated graphics built in. my Idea was to somehow connect send the Mic audio to my home server with an Nvidia GPU, have that server take out the background noise with RTX Voice and pump it back to the laptop through it's onboard audio. As a LAN configuration would be useless with the work VPN. any Ideas on how this could be done or what I need to order?
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/1186836-remote-mic-audio-processing/
Well, you'd just need to send raw audio to your computer then us VB audio cables to route it through RTX voice then send the audio back to your laptop.... but that would introduce a bunch of latency and likely be a very unstable system. THeoretically, so long as you find a way to send the audio between devices without excessive compression/processing you don't need to buy a thing.
Oh, but, if you ever wanted to use audio on the server for other things you'd have to swap audio ins and outs every time, might be a pain in the ass
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
