Corsair RGB Questions
Pancake
I am totally out of the loop with regards to RGB... so forgive me
I want to build a new machine with some Corsair LL140 RGB Fans, and some CORSAIR Vengeance RGB Pro memory
Other than the fans themselves and the DIMM's themselves, do I need anything else to control all the RGB? It looks like some kind of hub may be required for the fans, what about the memory?
For the memory you don't need anything else.
The fans have two cables that come out of them; an RGB cable and a fan cable. The fan cable just plugs into your motherboard, the RGB cable goes to a hub.
What exactly are you buying? As in how many fans? in what quantity (as the LL140 comes in a pack of two or just by itself)?
You need their fan controller and RGB controller, which are separate, for the fans atleast. The fan controller is only if you will be using more than your motherboard would support.  The memory itself is plug and play, just use iCue
Moist
