75 is not overheating yet, dont worry until it goes past 83
Desktop benching:
https://linustechtips.com/topic/1186397-rtx-2070-overheating/#findComment-13542793
3 minutes ago, Rockers066 said:
I mean that’s with like 30mins of play I’ve already reached 82 or somewhere around there never had a gpu run so hot
What case are you using? If you don't have enough airflow than the graphics card will run hotter.
https://linustechtips.com/topic/1186397-rtx-2070-overheating/#findComment-13542816
lol, my GTX 470 used to run ~88-89 on water. haha. good times. It was also overclocked 46% but I mean, still.
82 is warm, but its not excessive. I assume your case airflow must be poor, or its right up against something that is heavily restricting its airflow. A 2070s should be in the 60's to low 70's while gaming. As @The_russian said, what case are you running? Is the GPU in the top most PCIe slot? Is anything beneath it? Is it a blower style of a custom fan card?
https://linustechtips.com/topic/1186397-rtx-2070-overheating/#findComment-13542833
