A few questions on converting an old PC to a NAS
13 minutes ago, HeLiOn said:I figured passive cooling doesn't need as much maintanance over time. Anyway, noted.
I mean yea it has less to fail, but fans just don't fail often now. Id keep the current cooler for now.
14 minutes ago, HeLiOn said:If they're fast enough, then HDDs it is. I figure I'd opt for 1 12 TB drive and add more as time goes.
Yea speed will be more than plenty. A single hdd can stream 4+ 4k steams easily. Your gonna be network limited first normallty
14 minutes ago, HeLiOn said:I just saw that Seagate has specific hard drive models designed for NAS stations (the IronWolf series).
I assume I don't need the drives with bigger buffers, given the purpose of this NAS. am I correct?
WIth current hdd pricing id get the exos drives, there normally cheaper than the ironwolfs and better.
Or get the cheaper external drives, probaby a bit worse, but the price savings makes up for failure rate easily
