4 minutes ago, Kraevyn60 said:
Would it be worth my trouble to replace my R9 390 with an RX 580? Im running an older processor (4790k) How much improvement would i see? My budget is limited so was wondering.
That limited budget , what is it exactly lol
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1186010-r9-390-replacement/#findComment-13539933
No, they have very similar performance levels, so you might as well wait until you can afford something like a 5700/2060S. Though, with a haswell i7 you'd start seeing bottlenecking in some games.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/1186010-r9-390-replacement/#findComment-13539934
The 580 is barely faster than a 390.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1186010-r9-390-replacement/#findComment-13539956
As @ibabyslapper said, they're pretty much trading blows in terms of performance ;
https://www.anandtech.com/bench/product/1868?vs=1747
So, unless you want to lower your PC power consumption and you're playing a game where the 580 is slightly ahead (DX 12 games for exemple), then it's not worth it and it's better to wait a bit and get something faster than a 580.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1186010-r9-390-replacement/#findComment-13539964
26 minutes ago, Kraevyn60 said:
Thanks for the responses guys.....what about something along the lines of a 1660 super?
if your budget is around 250ish get a 1660 super if your budget is around 280ish get a 5600xt or a 2060 ko
if your budget is around 650ish to 400 a 5700 or a 2060s is the best
Build Log:
https://linustechtips.com/topic/1186010-r9-390-replacement/#findComment-13540336
