9 minutes ago, T4ctile said:
https://pcpartpicker.com/user/T4ctile/saved/#view=Y8kmkL
What do I need to get to run all my fans plz help
Are you going to use 3 of the LL120 fans on the CPU cooler, or will you use the fans on the AIO + nine LL120 fans in your case?
Your board has:
1x CPU fan header
1x CPU OPT fan header
2x chassis fan header
So you use the CPU fan header for the CPU cooler's fans, so then you have three fan headers for left 6 or 9 fans (depends on if you're going to use the default fans with the radiator or not).
So you just need to get three fan splitters (either you need three or two fans splitter from one to three fan connections. Depending on if you'll be using the default fans or not.
The RGB stuff kinda goes like this:
(you get a single RGB Fan LED Hub and a single Lightning Node Pro with each three pack of LL120 fans, so you're all good there).
You could also get a Commander Pro, plug six fans into there and three fans into your motherboard. That way everything fits already.
The Commander Pro would also take the place of the Node Pro.
So will you be using the default fans from the AIO or not?
TL;DR: you need to get some fan splitters. How many? Depends on how many fans you'll use.
https://linustechtips.com/topic/1185955-need-help/#findComment-13539646
