I ran the "UserBenchMark" test on my computer and it said everything was working at or above average, except my CPU was in the 0th percentile. I have had bad FPS in my games considering my specs (30 FPS in RlCraft, 60-100 FPS in Overwatch). I don't know much about computers and if the FPS problem is related to the CPU
CPU: AMD Ryzen 5 1600AF
GPU: Nvidia RTX 2070
RAM: Adata DDR4 3000 2x8GB
https://linustechtips.com/topic/1185739-help/
List your full specs, including the power supply
Do you have XMP on? What are temperatures like?
https://linustechtips.com/topic/1185739-help/#findComment-13537958
And is the RAM running at 2133mhz or 3000mhz (use CPU-Z to verify this)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1185739-help/#findComment-13537977
Its running at 2933mhz (which is good for first gen Ryzen, but the AF is second gen'ish, which also supports up to 2933mhz) so that isn't the issue (DDR stands for double data rate, so you take that number, times two to get the frequency)
https://linustechtips.com/topic/1185739-help/#findComment-13537989
1 hour ago, NZgamer said:
That's pretty good, so nothing to do with temps, I think it is the XMP thing
So I went the the UEFI setup (I'm guessing that's the same as BIOS?) and under "OC Tweaker" was "Load XMP," there were two options "Auto" and "XMP 2.0 Profile: DDR4-3000 16-20-20-38 1.35V." It was on Auto so I left it like that because I didn't know what the profile is
https://linustechtips.com/topic/1185739-help/#findComment-13538465
