Mainboard: Gigabyte Aorus Pro B450
Processor: Ryzen 5 3600 Stock. (Can't get temp's down past 50° even with AIO.)
Memory: Corsair Dom Plat DDR4 3200 32Gb 16-18-18-36
Graphics: Asus ROG Strix 1080
Bios: Ver 0.5 19 update.
Cooling: ASUS ROG Ryuo 240 AIO
Hey there guys,
I know that I have been annoying in the without details but I thought I would pop in and try for help again.
So, I have noticed now that even with adequate cooling, when I am running anything at 144hz with clear headroom. I seem to have microstutters in games. Especially CS:GO.
I know it favours Intel chips more but still, I am getting well over 144 FPS (I lock to 144). I just can't work out where these stutters are coming from.
Minecraft does the same. I am currently running a Minecraft server with no issues on my older chip. Now if I walk more then 10 blocks I am getting that microstutter. (Lock up if you will)
Any help would be appreciated.
Cheers guys,
https://linustechtips.com/topic/1185708-micro-stutter-pc-issue/
24 minutes ago, BrockyTM said:
Yes, yes I have.
🤔 Have you tried using Nvidia's 'Fast Sync' feature? You can also try using their 'G-Sync feature as well if you have that kind of monitor. One thing I would try is simply reinstalling the game itself. That worked more often for me than updating the bios, operating system and GPU drivers, although those are things you should check if you haven't.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1185708-micro-stutter-pc-issue/#findComment-13542672
