Both will, so get the one that's a better deal and upgrade the CPU in the future
Desktop benching:
https://linustechtips.com/topic/1185378-bottle-necking-advice/#findComment-13535158
9 minutes ago, Arrow10271997 said:
Hello!
I have core i7 2600 cpu with 16gb ram I need advise in choosing graphic card.
GTX 1660 super or rtx 2060 which will be best fit with my cpu or both will bottle neck. Thanks.
I would say make or buy a new PC Because i7 2600 is to old so and I would go any buy 1600af
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-2600-vs-AMD-Ryzen-5-1600AF/620vsm563877 which will not cause any bottleneck
Hope it helps
https://linustechtips.com/topic/1185378-bottle-necking-advice/#findComment-13535171
Thanks for your reply,
I will upgrade my system in future but I wanted to make sure is it possible to get good gaming experience on 1080p with the combinations I mentioned.
https://linustechtips.com/topic/1185378-bottle-necking-advice/#findComment-13535185
