Judging by the looks of the system, I would say the bearing is likely frozen up from dust over the many years its been in service. Time to get a new cooler.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13527528
2 hours ago, ProMarcs said:
Just two years :// Will it maybe start if I clean the dust more carefully?
You could try. But I think it's better to get a new cooler.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13528005
7 hours ago, LogicalDrm said:
If these don't work, then its time for new cooler
If you can't get the fan to start with dusting using compressed air, you most likely won't need an entire new cooler. If the fan is dead and your heatsink is still in good shape, you may be able to purchase a replacement fan online. What model of cooler are you using and what socket type does your motherboard utilize?
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13532170
Looking at the cooler, one can get better for $20 (or less). Why waste money on some 80-92mm fan? It looks like model where its more effort to swap the fan than what its worth.
Edited by LogicalDrm
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13532219
You could replace the fan on the cooler for much less than $20 (more like $7 to $10). Although, if were having thermal issues or the old cooler was loud, it would be a good reason to upgrade to a better model with a larger/better-designed heatsink and quiet fan.
@ProMarcs; If you weren't able to repair the fan on your current cooler, and the motherboard is one of the following socket types, I would recommend upgrading the cooler to the DeepCool Gammaxx 400 LED:    LGA20XX/LGA1366/LGA115X/LGA775, AM4/AM3+/AM3/AM2+/AM2/FM2+/FM2/FM1
        @Boomwebsearch
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13532361
12 hours ago, ProMarcs said:
I replaced the cooler. is this normal?
What are load temps? I'm personally use OCCT.
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13538706
Looks fine. Though that software reports voltages and CPU usage bit weirdly. Maybe try using another software. HWiNFO or Afterburner, or even CPU-Z.
https://linustechtips.com/topic/1184325-cooler-not-spinning/#findComment-13539690
