Perhaps read the documentation of what you downloaded? Executable stuff is usually put in the bin folder.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1184193-help-on-class-files/#findComment-13527393
8 hours ago, LazerAyes said:
Can anyone help me with some files, I downloaded some files on github that I don't understand how to run it, it has .class files and .java files. Can anyone help me?
Did you download a compiled project or not?
What are you trying to do?
As @tikker suggest, read the documentation. (See the 'doc' folder)
These usually have an explanation on how to run the program/open the project (depending on if you downloaded a compiled program or not).
https://linustechtips.com/topic/1184193-help-on-class-files/#findComment-13527425
