really bad
Desktop benching:
https://linustechtips.com/topic/1183084-hot-ryzen-2600/#findComment-13519405
3 minutes ago, Pcbuilder2020 said:
What can I do?
Undervolt, undervolt, undervolt.
Offset voltage:
Start with -0.050 Volts (or 50mV), proceed to .075 or even 0.0825. Keep dropping voltages, until it's stable, and performance does not deteriorate.
Or you might just fix the core voltage& clocks, something like 1.12V & 3.7Ghz or such.
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1183084-hot-ryzen-2600/#findComment-13519419
Offset voltage:
I’m running at 3.2ghz
https://linustechtips.com/topic/1183084-hot-ryzen-2600/#findComment-13519428
9 minutes ago, Pcbuilder2020 said:
What can I do?
redo the thermal paste
Desktop benching:
https://linustechtips.com/topic/1183084-hot-ryzen-2600/#findComment-13519431
Try repasting the thermal paste.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1183084-hot-ryzen-2600/#findComment-13527182
3 hours ago, Pcbuilder2020 said:
I used artic and it’s about still high 93-95
Are you referring to original installation or repaste?
Are you using default motherboard settings? What case are you using and how is your case airflow setup? Fan rpm?
https://linustechtips.com/topic/1183084-hot-ryzen-2600/#findComment-13547227
