21 hours ago, Grabhanem said:
What cooler and CPU?
Ryzen 3 3200g and the amd wraith max I think
21 hours ago, boggy77 said:
also what temperatures? did you clean the cpu properly and apply thermal paste when installing the new cooler?
Yes I did clean it off and reapplied thermal paste and it's like on 60C under load
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516295
SO before it was 35c under load?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516302
Stock cooler not a cooler that's 2 times as big the stock one
Yes
Can anyone help plz
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516341
Would really need to know what Cooler you are using and what cooler you were using, but if its that bad, and it should perform much better, you may have just installed it incorrectly
or its literally you put something with a lower capacity than what you had before so its getting heat soaked.
AND new fans ? what are they? how have you installed them ? what direction is the air flow in your case? do you run positive pressure?
ICT professional, Addicted to PC
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516387
I had the stock cooler and now I have the wraith max I think it's like the wraith prism but with less rgb and I installed 3 new coolermaster halo 120mm fans and they are out and 2 200mm are intake
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516401
ANd Fx8350, dude that's like a 9 year old processor! it runs hotter than what you have but I wouldn't personally put a CPU cooler for a FX8350 onto a Ryzen, the cooling footprint is larger on the ryzen i believe (I have owned the FX8350) now run a ryzen 7 put your old cooler back on.
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516437
It supports ryzen cpu's
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516453
20 hours ago, Technane said:
Well from what you are saying.. its not supporting it very well
It's the same footprint as the prism so it cant be that
And I dont have the money for a new cooler I dont even have a gpu i use integrated graphics all the money I earn rn Is going to a new gpu so
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516474
This is not how coolers WORK not in the slightest, heres the cooler we are talking about https://www.eteknix.com/amd-wraith-cpu-cooler-fx-8350-review/
Can you show me where you have seen that it supports Ryzen? as I wanna stand by my point, do not use an 8yr old CPU cooler for a different platform on a new one!
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516530
47 minutes ago, kes2006 said:
Yes
Sorry, no CPU is 35c under load.  Regardless of air cooler.
I think you need to accept that 65c under load is perfectly fine.  Because it is.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516532
On the amd site
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13516585
5 hours ago, kes2006 said:
Yes
35c is unrealistically low without a large AIO or custom loop. What are you using to test for load and measure temps?
65c isn't overheating and is actually pretty good.
The stock plastic hooks are shared on AM4 and AM3+. Coolers that use that stock mounting mechanism can fit on either socket.
https://linustechtips.com/topic/1182661-cpu-overheating/#findComment-13517451
