Seeking portable monitor recommendations
For Science!
Hello all!
Seeking some recommendations for a portable monitor for gaming purposes, here are some information:
Budget: Unlimited, would rather buy something of quality once than upgrade
Output sources: PC, Nintendo Switch
Purpose: A monitor to be used by my bedside for gaming that can also be taken on the go when needed. I would need some way to either mount it onto a VESA mount, or alternatively a tripod mount style that are found on DSLRs.
In order of importance of features:
- Availability in Germany/Europe
- Fast refresh rate
- IPS, good color accuracy
- Able to mount either onto VESA or a tripod mount
- Low input lag (fast response time)
- 1080p
- 15 or 17 inch
Basically I am considering the Asus XG17 which is actually available, but the mounting system for the tripod is not available yet. Perhaps it is pricey but as above, I would like to buy something great once and be happy with it.
