Hi guys!
I'm wondering if everything i chose is compatible and IF it is a good pc to build!
please say everything that comes up with this build :)
Need feedback and tips
ALSO, i haven't chosen a case yet.. what do you suggest?
Thanks!!
https://linustechtips.com/topic/1182018-is-everything-compatible-need-help/
My advice is put some SSD in, at least for the system ~250GB, I would recommend ~500GB for games. And That PSU is good, but your configuration will never drag as much as 750W, I think 650W PSU would be more suitable and also more affordable.
Case is very subjective but my suggestions of cases I like: NZXT H510 [Elite], Fractal Design Meshify C, Phanteks Eclipse P400A(S)
PCPartPicker Part List
CPU: *AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (€323.95 @ Bytes At Work)
Motherboard: MSI B450M MORTAR TITANIUM Micro ATX AM4 Motherboard  (€120.95 @ Bytes At Work)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  (€105.95 @ Bytes At Work)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  (€81.95 @ Bytes At Work)
Storage: Toshiba P300 2 TB 3.5" 7200RPM Internal Hard Drive  (€66.89 @ Alternate Belgium)
Video Card: MSI Radeon RX 5700 XT 8 GB MECH OC Video Card  (€424.05 @ Azerty)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  (€84.89 @ Alternate Belgium)
Total: €1208.63
Generated by PCPartPicker 2020-04-22 12:05 CEST+0200
better motherboard (msi x570 boards have bad vrms), faster ram, nvme ssd, better gpu (the mech and evoke have thermal issues) a good case and a less overkill psu.
yeah its actually a WD 1Tb SSD :)
don't added a HDD.
Ok i'll go for a 650, and i'll look at the cases. all the components fit in alle these cases?
My suggestion
If you prefer sticking to X570 boards, get the Asus X570-P.
Not sure what you ask from a case, so I just picked one with mesh front and transparent side
Added case fans for airlfow
Added cooler because the stock one is rather weak
12 minutes ago, klapstok said:
MSI X570 boards below the Unify are not competitive with those from Asus Asrock and Gigabyte for the price, those below the Carbon arent even better than their B450 boards in any significant way.
3600MHz memory is basically at the same price range (3600MHz CL18 kit of Corsair Vengeance LPX), so more speed is better. Spend more for a CL16 kit since it's not that much more anyways
Changed the SSD purely because WD Blue is previous gen stuff for only slightly cheaper, though the gains arent significant so either will do
One of the worse coolers on a hot GPU (225w class), replaced
overkill PSU, dont need to go beyond 80+ Gold efficiency unless electricity is really expensive (since we're talking about only 2-3% efficiency gain, it will take forever for the PSU to pay for itself)
Desktop benching:
thank you very much!
3 minutes ago, Jurrunio said:
My suggestion
I love this! Thanks man
