Hey guys I have done a small bit of research into my build but I just need some double checks and opinions. Quick background, I want to play mostly FPS games like csgo and Rainbow 6 at 1080p on a 144hz monitor, my budget is around $2300 Australian or $1500 USD. So the questions I have are;
1) Does my PSU have enough wattage
2) Is the GPU a good quailty pick
3) Is it worth spending the extra $50 for a MSI Nvidia RTX 2070 VENTUS GP 8G when I only want to play at 1080p (Also I dont want to switch to a Radeon GPU)
4) Will I need to do a BIOS Update (as in get a spare CPU from Ryzen) or is the motherboard "fine" with the CPU.
5) Is Ryzen's own CPU cooler enough
6) Do I need to purchase any extra cabels or themal paste, ect
6) What is a good $100 USD gaming keyboard
[PCPartPicker Part List](https://au.pcpartpicker.com/list/MKnpMc)
Type|Item
**CPU** | [AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor]
**Motherboard** | [MSI B450 TOMAHAWK MAX ATX AM4 Motherboard]
**Memory** | [Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory]
**Storage** | [Samsung 970 Pro 512 GB M.2-2280 NVME Solid State Drive]
**Storage** | [Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive]
**Video Card** | [MSI GeForce RTX 2060 SUPER 8 GB VENTUS OC Video Card]
**Case** | [Corsair 100R ATX Mid Tower Case]
**Power Supply** | [Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply]
https://linustechtips.com/topic/1181618-first-pc-build-need-double-checking/
@GazzaMate Yes you will need to update bios, for the keyboard depends on what kind of feel you want for the keyboard. I would go for a non stock cooler for a 3rd gen cpu, it would be "enough" but it would get a little toasty. I would say the extra 50 isn't really worth it, it's a marginal FPS increase. Most coolers come with thermal paste these days, your GPU quailty is good i use MSI for my cards as well.
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
1) Yes.
2) The Ventus isn't really a great pick, as it might run louder than other cards because of its fairly small heatsink.
3) The 2070 offers an unnoticeable performance advantage over the 2060S, so no. Also, why don't you want to consider AMD?
4) MSI's "MAX" boards are ready for Ryzen 3000 out of the box, so no.
5) It's alright for stock speeds.
6) No, assuming you already have a display cable for your monitor.
Also, the 970 Pro isn't worth it unless you're using it as a scratch disk. Get a 970 Evo, Sabrent Rocket, Adata SX8200 Pro or HP EX950, you could get a 1TB version for either drive for that money.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
When updating BIOS do I just take the PC to my local computer guy and get them to do it or is there an easier way of doing it?
that build what i posted has already been bios updated to support the ryzen 5 3600
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
you can do it yourself. But there is no need MAX boards are ready out of the box my mistake
So do you think it would be better getting the 3600 instead of the 3600x?
the perfomrnace increase is marginal for an 18% increase in price
Yes, it’s not worth the extra money for slightly higher clock speeds especially when you can just over clock it.
pc specs:
CPU:
Just now, GazzaMate said:
I dont do editing or streaming but I may run CAD and rendering software as I need it for my uni corse.
Yeah, should be good for that.
pc specs:
CPU:
3 minutes ago, GazzaMate said:
@Shrekpad Sorry final thing, I was planning on getting the parts from both umart and MSY but are the prices and websites on pcpartpicker reliable, ie can I just get all the parts from pcpartpicker?
Not sure in Australia, but here in the US they have reliable retailers.
pc specs:
CPU:
7 minutes ago, GazzaMate said:
I am pretty sure this will be the final build, final question, do I need a CPU cooler? (will not overclock)
https://au.pcpartpicker.com/list/LJ9C9G
No, you most likely won’t run into temp issues with stock cooling.
pc specs:
CPU:
