My first build
Go to solution Solved by Hold-Ma-Beer,
13 hours ago, Flaxe said:
Cable management was pretty nice, and the aesthetics are very nice, however, quote me if i'm wrong, but i'm noticing some gpu sag.
He fixed it. Se in the next pics ;)
My first build and pc. Switching over from console finally. It also is a budget build. I plan on getting a bequiet cooler for the cpu soon, and a 500 gig ssd for my main storage and will use the hdd for back up. Tell me what do y’all think?
Ryzen 5 2600
Msi rx 580
16 gb ddr4 3200
asrock b450m pro 4
evga 600 watt bronze
120 gig nvme
1tb WD blue hard drive
Corsair iCUE 220t
https://linustechtips.com/topic/1180850-my-first-build/
pretty nice! Are you gonna upgrade the gpu to next NAVI or rtx 3000 -series?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502870
Nice and tidy, well done
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502872
Just now, shaneh890 said:
I was looking at a rx 5700 xt, but that won’t be for a bit, so who know what I will decide on
5700 XT not worth the upgrade right now. wait like 6 months and get new NAVI
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502880
Ryzen 5 2600
Msi rx 580
16 gb ddr4 3200
asrock b450m pro 4
120 gig nvme
Corsair iCUE 220t
I would like to point out that your GPU is sagging like hell...
But other than that, the build is pretty neat.. (way better than my first build... *me not knowing that cable management exists)
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502886
Yes in the first picture but I realized it and ordered a bracket (as seen in the other pictures) and solved it
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502889
Yes it will probably be about 6 months or so until I can spend some more money on it, since I had to buy peripherals and a desk and stuff. I will probably stick with amd cards because my monitor is freesync
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502894
Not bad. Personally I wouldn't have bothered putting money into a 120GB SSD though.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502895
I just wanted something to boot off of quickly and will be adding another larger ssd once I have some more money saved up. The 120 gig only set me back 40 bucks
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502902
Yeah but one twice the capacity isn't much more, and a 1TB is only $100.
NVME in 120GB also doesn't make much sense since smaller capacity drives are slower.
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502903
22 minutes ago, WarNeverChanges said:
Nice build man, Super clean looking it all ties really well together. All it needs is a beefy air cooler and then overclock the life out of it.
Yep I’m looking at a be quiet dark rock 4. My friend keeps insisting I get an aio but I think an air cooler would look better
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13502981
Good choice! I have had AIO Water-coolers before and honestly i think High-end air coolers are better, I had an AMD FX-6300 overclocked to 4.8Ghz on a Noctua NH-D14 and it ran great.
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13503006
49 minutes ago, Hilltrot said:
Even better, wait like 6 months and switch to Nvidia.
nobody knows how powerful nvidia and NAVI cards will be. if NAVI decently priced, like rx 5700/XT then NAVI makes more sense. but if (finally) NVIDIa comes with decently priced gpu then go to nvidia. simple
https://linustechtips.com/topic/1180850-my-first-build/#findComment-13504068
