I need help for amp/dac comparison.
ManosMax13
I want to compare 2 amp/dac combos and I want them to be at the same volume. However 1 is way louder than the other is there  a way to see how much is amp/dac is outputting so I can change the volume accordingly?
If you have a microphone, record the same speaker/headphones from the exact same distance and location with each amp. You can look at the audio files and see which is louder.
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
