Linus, i have a gigabyte h370n wifi, and an 8500 with a gtx 660 running as my server, but im running windows. Right now its being used for 7 days to die but was wondering if there were any other ways of configuring this to get better connection speed or making into a better server. I have a 4tb ironwolf nas hard drive and a 256gb m.2 in it for storage along with a 2tb portable hard drive, idk how to configure the system to store evertyhing on the portable as a backup, can you help?
https://linustechtips.com/topic/1180706-help/
use a backup program to backup to the external hdd.
Idtake that gpu out, its just wasting power unless something is using it.
https://linustechtips.com/topic/1180706-help/#findComment-13504524
If gpu is doing nothing bin it. Extra power draw for 0 gains
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
https://linustechtips.com/topic/1180706-help/#findComment-13504701
