Hello
I've just purchased a Super Flower Leadex Gold 850W PSU (SF-850F14MG) on ebay, have now realised that it hasn't been sent with any cables.
The seller doesn't have them, and I've read that modular cables are definitely NOT cross-compatible.
Do I have any hope, or will I just have to get a new PSU?
Thanks in advance
https://linustechtips.com/topic/1180609-super-flower-modular-cables-help/
9 minutes ago, talentednuisance said:
Hello
Thanks in advance
I would send the PSU back to the seller and demand a refund.  The thing was sold as a partial device.  Complain to eBay if needed.  No power cables is crazy.  The things are useless without them, and they very often can’t be bought.  Even if you were able to find separate cables they would likely cost more than a new PSU to begin with.
12 minutes ago, talentednuisance said:
Hello
Thanks in advance
Leadex I, II, or III? It matters here. But i should be able to point you in the right direction with that information
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
8 minutes ago, talentednuisance said:
Hello
Thanks in advance
Unless the seller specifically mentioned he was selling the power supply only/ the power supply without the cables then ask for a refund and send the product back. The power supply was originally sold with it's own cables anyway.
If you're in UK, Overclockers seem to sell the power supply cables you need but they are aproximately 70 pounds so you're probably better off trying to return the psu and getting a new one. https://www.overclockers.co.uk/super-flower-braided-cable-kit-black-ca-051-sf.html
Leadex I.  The one with the funky 9-pin connectors.
19 minutes ago, talentednuisance said:
Hello
Thanks in advance
Ask for a refund.
Those 9-pin cables are going to cost you as much as a new PSU.
Ah... I had one of those, ended up throwing it in a prebuilt that only needed the few cables i had for it.
34 minutes ago, talentednuisance said:
Hello
Thanks in advance
The only feesable solution would be to make your own PSU cables, which though isnt hard takes a lot of time as you really need to make sure you get it right the first time. I found a seller in Germany that is the 12 and 18pin connectors (the ones you need for your 24 pin). But, the 9 pins are out of stock through that seller. I found another, but theyre $10 a piece. This COULD be feesable cost wise, but is a big time investment and probably not worth it unless you got an absolute STEAL on that PSU. Which, i'd hope you did if it didnt come with any cables...
EDIT: Of course you need the bullet terminals as well. I dont know what size they are.
18 pin- https://blacktec-designs.com/de/cablepc-modding/connectors/special/201/18-pin-superflower-psu-connector-transparent
12 pin- https://blacktec-designs.com/de/cablepc-modding/connectors/special/200/12-pin-superflower-psu-connector-transparent
9 pin (out of stock as of right now)- https://blacktec-designs.com/cablepc-modding/connectors/special/199/9-pin-superflower-psu-connector-transparent
9 pin (overpriced)- https://www.moddiy.com/products/Super-Flower-Kingwin-Crystal-9-Pin-Modular-Connector.html
Useful threads:
Total: $1891.98
