Hey guys, I am looking to change my case, because DF-35 (this thing suck)... I want to keep it under 150$ and i live in Québec, Canada. I want something that smells quality and preferably not to big. With the less plastic possible. The case i have right now does not close because of my nh-u14s tower cooler.
Here is my rig :
OCZ modxtreme pro 700w (the cable are very short, so i need space for extension)
Asus m5a97
AMD phenom 965 BE
Noctua NH-U14S
Asus 7970 DCUII (this thing is feaking long and big, Will probably crossfire in a year when it cant handle new games)
Current case : Antec DF-35
I bought 4 corsair sp120 QE 4 weeks ago that i'd like to fit in the nre case
One thing to note is I don't plan on ever water cooling, I like the look of air cooler and i don't see the need as i don't overclock my component to far.
Thanks!!
Case : Corsiar Air 540 CPU : Intel i5 8600k GPU : Asus Nvidia 970 DirectCUII RAM : 16gb DDR4 MB : ASUS Prime z370-p PSU : OCZ Modxtreme 700w SSD : Samsung 840 EVO 250gb
https://linustechtips.com/topic/118009-atx-case-under-150/
fractal r4
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574060
Here is my rig :
Asus m5a97
AMD phenom 965 BE
Noctua NH-U14S
Thanks!!
you might like a Lian Li case
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811112411
It's more or less the same as a Fractal Arc but with less plastic.
Error: 410
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574078
If you do mind the all plastic front of the Define R4 or Arc Midi R2 then go with something from Lian Li since they are all metal with a nice brushed aluminum finish.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574096
I am note to sure aboute the way the side window is mounted and the cable management does seem to good :(
Is the xigmatek Talon any good? altought is is plastic, i find soft touch plastic to be quite attractive.
fractal r4
Is the front of the R4 all aluminum? or is it plastic with aluminum texture?
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574113
Fractal r4
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574123
The front door is plastic with rigid plastic bezel. It's indistinguishable and actually has a kind of nice shined finish, the front of mine kind of looks like a white mirror.
The Lian Li one is all metal and should have similar space in the back to the R4.
http://imgur.com/a/cQQNp (this build is flat out retarded IMO, but it's just an example to show the cabling, by the way if you buy a brushed aluminum case clean the fingerprints off with alcohol immediately after handling it unlike this tool who rubbed his grubby hands all over it and didn't bother cleaning it)
You can also consider a Midi R2, it's cheaper than the R4 and the Lian Li while having the same layout of the R4 with more air flow. Keep in mind the R4 is not designed for thermal performance.
The Talon is a little tacky for my taste.
this may help you decide
Error: 410
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574131
CM Storm Stryker if you like the look. Its all metal and really good construction. Paintjob is solid and the airflow is superb :)
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574219
That case looks amazing compared to the R4... Wish I considered Lian Li more when buying
CPU: i7 4770k @ 4.3Ghz with NH-D14 | RAM: 16GB Corsair Vengeance 1600MHz | Motherboard: ASUS Maximus VI Hero | GPU: SLI GTX780 Windforce | SSD: Samsung 840 Pro | HDD: WD Black | PSUEVGA SuperNova 1300W | Case: Fractal Define R4 | Monitor: X-Star DP2710 1440p @ 96Hz | Mouse: DeathAdder  | Keyboard: CM Storm CherryMX Red | Headset: Kraken Pro | Headphones: HE-400
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574279
Cooler Master Cosmos SE, Corsair 600T, Corsair 750D, NZXT H440.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574286
Right now i think the battle is between the C70 and the 750D.
The side mount for fan would be good because is mine with my graphic card, But the front of the 750D is just soooo beautiful.
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1574374
check out the air 540~
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139022
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1576955
I am actually doing just that at the moment haha. The mate plastic is a good replacement to front aluminum, and the air cooling seems to good enough so that my 7970 dont bake itself while mining xD The PSU is placed so that my short cable on it will easilly be able to reach. What i don't like is that it is wide, but hey, you gotta make sacrifice sometime :P
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1576974
It does have that unique look to it xD but also Cooler Master is making there own case in that kinda style. the working name is the Cooler Master XC.
http://community.coolermaster.com/uploads/monthly_01_2014/post-89696-0-66504900-1389002890.jpg
I think the look is slightly better, but that could just be me  =3
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1598463
NZXT H440 FTW  B)
Future Build : Intel-Core i7 4790K : Corsair H100i : Asus Maximus VII Hero : Corsair Vengeance Pro 8GB (DDR3-1866) : Samsung 840 EVO 120GB : Seagate Baracuda 1TB : Asus GeForce GTX 770 : NZXT H440 (Red/Black) : EVGA SuperNova G2 850W :
 Acer H236HLBMID Corsair M45 Mouse : Ducky Shine 3 (Red LED/Cherry MX Brown) : Audio Technica M50RD : Some Nice Cheap Mouse Mat
Peripherals :
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1598534
If you haven't decided on a new case yet, you should look at the Corsair Vengeance C70. It is made of 100% steel.. Here is a review of the case done by the man.. the myth.. the one and only Linus: https://www.youtube.com/watch?v=kgICPSE-zYQ
The case comes in 3 different colors.. Military Green, Black, Arctic White. The Military Green is the most expensive on Newegg.com at 139.99 USD.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1604814
Not to mention the external (??? idk, not that bad) 120mm CLC, a 650Ti with like a million case fans and an 860W power supply.
The dude spent more on case fans and CPU cooling (maybe even unincluding the H80i) than his graphics card I think...
https://linustechtips.com/topic/118009-atx-case-under-150/#findComment-1604950
