Looking to upgrade my rig partially.  I plan to go with an i9-9900 so I need a new motherboard.  Problem is, I haven’t done a build in a few years now and trying to figure out what is decent right now for mobo’s is a nightmare.  It seems everyone has some sort of problem with every manufacturer.  Anyone know of a reliable Z390 board that’s fairly easy to OC with?  Trying to get some help from people with experience vice just reading disgruntled reviews from unhappy customers at this point.  Thanks in advance.
https://linustechtips.com/topic/1179828-motherboard-help/
Certainly when it comes to going with Intel's 9900. It's locked so it cant even show its only advantage to Ryzen, and Intel's cutting board compatibility with next gen again so buying it today is still a bad idea when ignoring Ryzen.
Desktop benching:
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495208
Well if I were to move over to AMD, what’s the Ryzen equivalent to the 9900?  And what’s a good/higher board?  Been intel this entire time so haven’t looked much at AMD.
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495220
get a 3900x
It's a far better chip considering you can do tons of things that you can't with the i9-9900
Get a good motherboard, I'd prefer Asus strix ones for build quality and longevity.
You'll se debates about intel's single core performance and extra fps and so on.
But the ryzen 3rd gen's ipc is better than intel. Linus mentioned in a video that considering the ipc rates, ryzen is somewhere like 5.03gHz and intel like 5.1gHz when the exact task is considered.
If i were in your shoes, I would've gone for r9-3900x.
Btw, I have a i5-9600k and I was a intel fanboy until ryzen 3rd gen
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495237
ryzen 7 3700x/ryzen 9 3900x with "msi b450 tomahawk max" or "asus prime x570-P"
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495238
Ryzen 7 3700X if you want the same performance for less. Ryzen 9 3900X if you want 50% more cores at the same price
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495245
So, would something like this build be along the right path?  The PSU, GPU and case are carryovers from my current build.  The CPU, cooling, mobo, and RAM would all be purchased for upgrade.  Any comments or recommended changes?
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495270
Drop the water cooler. A Dark Rock Slim or hell, even the stock Wraith Prism, are enough for the 3900X.
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495279
Really, the stock cooler provided is enough cooling?  I mainly game so I suppose I’m not even gonna be fully loading a 12 core CPU.
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495317
As long as you're running stock, yes. aMD have pretty good stock coolers. Google the Wraith Prism so that you get an idea. It's not a tiny aluminium block like the intel ones, it has heatpipes, a copper coldplate and a decent DBB fan
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495338
59 minutes ago, Xion2552 said:
Memory Corsair Vengeance RGB Pro 64 GB (2 x 32 GB) DDR4-3600 Memory $349.99 @ Newegg
I would go for faster ram since you are paying this much for ram.With AMD's Infinity fabric technology Ryzen chips tends to get faster with faster RAM.
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13495379
What would you recommend then, I honestly was just going with a brand I knew tbh.
https://linustechtips.com/topic/1179828-motherboard-help/#findComment-13496586
