Will extension-cable affect impedance?
Go to solution Solved by The Flying Sloth,
If it helps answer your question, a very reputable audiophile ran tests, thousand dollar speaker cables against aluminium foil, surprising nobody there wasn't a difference.
Yes the Impedance will change slightly but as Dujith said above it really won't make a difference so long as the extension cable has metal in it.
Sloth
In my computer I have a dedicated soundcard (Creative Sound Blaster AE-5) and it can run headphones up to 600 ohms via its dedicated headphone jack (separate from speaker jack).
But I would like to have easier (and cleaner) access to plug in/out my headphones. Is it possible to use an audio extension cable  from that plug, or will this hinder the impedance somehow? Headphones requires 65 ohms of impedance.
And no, I'm not gonna buy an external DAC, as the AE-5 is more than excellent once it is setup properly.
Mobo: Asus Z370-A Prime
CPU: Intel i7 8700K
RAM: Kingston Fury 32GB (2x16GB) DDR4 3200MHz CL16 Beast
GPU: Gigabyte Aorus GTX 1080Ti Xtreme Edition 11GB
Case: Fractal Define R6 Tempered Glass, Black
SSD 1: Crucial P3 1TB M.2 PCIe Gen 3 NVMe SSD
SSD 2: Samsung 850 EVO 1TB
SSD 3: Crucial MX500 500 GB
HDD: Seagate Barracuda ST4000DM005 64MB 4TB 7200 rpm
PSU: Corsair RM750X v2
Display 1: AOC Agon AG271QG
Display 2: Dell U2711
CPU Cooler: Cooler Master Nepton 240M AIO
Mouse: Logitech G502 Proteus Core
Keyboard: Cooler Master CM Storm Trigger Z w/ Cherry MX Brown
Speakers: Creative Gigaworks T40 Series II
Soundcard: Creative AE-5 Soundblaster
Headphones: Sennheiser RS 165 Wireless
Microphone 1: Audio Technica AT2020+ USB
Microphone 2: Antlion Audiio ModMic Wireless
OS: Windows 11 Home 64-bit
https://linustechtips.com/topic/1177653-will-extension-cable-affect-impedance/
As for your title question, yes. Any extra length of copper will affect impedance as it will add (a tiny amount) of resistance.
Will you notice this? no. Unless you get absolute crap extension cables it will not matter.
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Sloth
Thanks guys! I was just worried that transferring the "power" would be dependent on the cables somehow; like you'd need something special like an "active" audio cable or something.
But if I understand you correctly, if I use a 1 meter extension cable of good quality and use e.g. a shorter headphone cable (I have 1.2 m and 3 meter) the signal should be the same as if I plugged the 3 m cable directly into the headphone jack? It's all about the source being capable of producing enough power, cable is irrelevant?
CPU: Intel i7 8700K
At that distance yes. the couplings are gonna be a bigger issue then the cable itself :D You will not notice a difference.
A quick calculation tells you this: 1m of extension cable with a copper core 0.8mm2 will be 0.021Ohm extra...so nothing :D
Thanks! I'm just such a noob when it comes to audio.
CPU: Intel i7 8700K
