so i am in severe need for rgb as my upcoming build has zero rgb in it. i think i need 2 400mm strips - one at the top one at the bottom, both near the tempered glass to iluminate the insides gently. i have like a $70 budget for rgb pls reccomend me a compatible one. my case is phanteks p300a and has an rgb front panel connector but im not sure if it should plug in into the motherboard(msi b450 tomahawk max) or directly to the led strips. i also do not really understand the different rgb softwares(mystic light, aura sync...) Do i need a software to control the rgb? preferrably available on newegg
https://linustechtips.com/topic/1177296-rgb-help/
just picka company and use their rgb starter kit. like get a corsair node and corsair light stripes and a few fans
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
https://linustechtips.com/topic/1177296-rgb-help/#findComment-13475991
