Help to finish my build
I would wait for Ryzen 4000 before upgrading the cpu. The 2700X is still good.
For the motherboard it depends on how much you want to spend. There are good B450 boards like the MSI B450 Tomahawk MAX and B450 Gaming Pro Carbon AC.
If you wanted X570 for some reason than any Asus X570 board is fine. For Gigabyte I would look at the X570 Aorus Elite or Pro. The MSI X570 boards are not so great until you get to the X570 Unify.
I would look at a 3200MHz CL16 kit as they are usually priced better than the 3600MHz CL16 ones.
The 850W psu is way more than needed. The 650W version is more than enough.
For the SSD I would just go with a single 1TB. So as you mention editing then the Corsair MP510 would be a good choice. There is also the Adata SX8200 Pro, HP EX920/950, Sabrent Rocket, Team MP34 and Seagate Barracuda 510/Firecuda 510. There are others but that is a good selection.
You can always add a SATA SSD or Hard Drive later if you need extra storage.
